Part Copy Display Issues
Builder
Builder
I am having display issues with parts that are comprised of "part copies". Some are ones I have created and some are from STEP files that I have either downloaded or imported. Im having the issues in both the assembly environment and the drawing environment.
Im sure there is some check box or setting that i can't find. Any help or suggestions is much appreciated.
Re: Part Copy Display Issues
They're most likely construction bodies or surfaces.
Assembly environment - Do a "Show/Hide Component" on the part and turn "Surfaces" on
Drawing Environment - Go to the "Properties" of the view, "Display" tab, right click the part with the surfaces and select "List Constructions", now select the surfaces and check the "Show" box.
Builder
Builder
Thank you.
