Part copy in body
My name is Marcel Faur, and I am macanichal design engineer.
I have a question.
How can I transform a 3D model of the part copy in body, because it can not do extraction boleean.
Thank you,
Marcel Faur
7 REPLIES 7
Re: Part copy in body
right mouse button:
Thank you so much.
But I don`t have that option there. look at the print screen.
If you know where I take mistake please tell me.
Did the Part Copy command warn about no design bodies in the selected file ?
I got the part, so I got it, I just had to do something for this part and I need it in body feature.
1. Did you get an IGES/STEP file that you opened in Solid Edge?
> In the file open dialog, click the Options button and match the settings as below:
2. As you mentioned you got the part, was it a Solid Edge part with the geometry already imported and given to you ?
> Save As Translated the part to either IGES/STEP and open back the exported file with the options set as above.
With this, you will get only one entry in the Pathfinder as Partcopy instead of the multiple seen now.
Right-clicking it will enable the Design/Construction toggle.
Hope this works for you.
~Tushar
Hi Tushar,
Thank you very much, it`s work.
Have a nice day!
Hi MARCEL1:
Glad, it worked.
Next, click the 'Accepted Solution' button for all posts that were useful to you in this discussion.
~Tushar
