Part copy not visible in assembly
I have a part that was built with a part copy. If I place this part in an assembly, this part is not visible. Why?
11 REPLIES 11
Betreff: Part copy not visible in assembly
Hi @KurtCouffez
what I can see on You pictures is, that the part copy seems to be a mesh body.
The question now is, which SE version are You using.
The usability of mesh bodies (STL, etc.) is much better with ST10 than in previous versions.
Wolfgang
Re: Part copy not visible in assembly
The part appears to be only composed of surfaces. If you show surfaces in the assembly you should see. You could probably fairly easily make it solid as well.
Or it's what @hawcad suggests.
Bruce Shand
Hi there @KurtCouffez,
By default, SE will place [& display] only "Solid Bodies" into an assembly, and there is an option to show construction geometry, if no solid is present.......but in your case, I think you'd need to just use the [RMB] context menu for "Show/Hide All Components" to display all else.
Solid Edge 2019 [MP8] Classic [x3 Seats - Cloud Enabled]
@hawcadthat doesn't appear to be a mesh body. When you translate an stl the thing that shows up in the design tree looks like this
Horrifying thing, stl files.
Solid Edge 2019
Windows 7 Professional
Nvidia K2200 & Intel Xeon
"You're doing it wrong"
@nominus38, awesome pic (and punchline). LOL. Any chance of sharing that file? It chokes me up a little. Reminds me of my mother-in-law.
Bruce Shand
Hahaha.....you win the internet today @bshand, THAT was darn funny.
.....but seriously....I'd like to get a hold of that model file too @nominus38.
Oh, I suppose. Once. However it is so large that it won't let me post here. So try this, I uploaded to my drive. Hope this works.
Hope the link works---->Alien
Solid Edge 2019
Got it....cheers buddy!
Thanks @nominus38
Bruce Shand
