Part copy settings
I would like to set SE so that whenever I bring a part copy into another part it is set so "automatic update" and "link material" are on by default. Is this possible?
Using SE since V12, 2002
ST10 certified
4 REPLIES 4
Betreff: Part copy settings
OK, found a way to fullfill the request
You have to save a part file with a part copy and a one time updated part copy as template for all new part files
You even can delete the part copy from You template file, but the option to auto update still is kept correctly
Works fine here for me!
PS..: of course mode is set to ordered!
Wolfgang
That works for auto-update, thanks, hawcad. However "Link Material" doesn't stick, is there any way to make that the default?
ST10 certified
seems that You are right.
Material optionn somehow might not be saved.
But didn't it in the past?
Wolfgang
I've never tried this before, I've always just muddled through, fixing as I go. Then one day I stop and say, "There must be a better way to do this!"
Larry
ST10 certified
