Part edit in orderd environment
N/A
When I wanted to edit a part it put me in the ordered environment, so I made the change and when I went back to synchronous the change didn't show up. How do I get edit to show up in the synchronous environment?
Re: Part edit in orderd environment
Hi there,
What kind of "Ordered" feature did you make?
...as usually you can just right mouse click on the ordered feature listed in the "pathfinder" and select "Move to Synchronous".
Solid Edge ST10 [MP7] Classic [x2 seats]
N/A
Thanks for your reply. It was an extrude command on a sheet metal part. When I go from ordered to synchronous it disappears, when I go back to ordered it reappears, I will try "move to synchronous" in the pathfinder, thank you for your help.
