Part modified in an assembly...
I'd like to know if is possible to modify a part in an assembly and all the other parts in the assembly related and linked to it will change dimension and shape accordingly. See attachment.
Re: Part modified in an assembly...
Are you on Traditional or Synchronous?
There are some ways and this post can help you:
link
BR,
Imics
Thank you.
Apart for the language settings used, which unfortunately I don't understand, I'll try that way to operate.
I'll keep you posted if I stuck.
Marco
Here is a link, I think you will familiar with this:
tutorials
BR,
Imics
there's a few different way's. this for ordered only - you can use interpart copy or create a variable. if you need more, i could make a video.
Thank you very much for your replies.
A video will be the best thing for me.
Thank you very much.
Marco
