Parting line
Are there any additional tutorials on how to use the parting split command? I've completed the one with the mouse found in the SE fundamentals documentation. I was wondering if you can use the parting split command to create a multi plane ( like the letter Z ) parting line . Thanks
Re: Parting line
Sorry the tutorial was from ST 10 Surfacing Activity J parting split and parting surface where the top reference plane is used to create the parting split. Is there a tutorial where a non planar parting line is created.
