Parts Come Up Missing
I replaced a sub-assembly in an assembly saved into a temp folder. Closed assembly reopened...
noticed some of the parts are missing again. Basically here of late parts coming up missing from the assembly.
Greg
Re: Parts Come Up Missing
Greg,
This would "normally" indicate the files listed as missing in the assembly, have been moved, or renamed....at which point there are a couple of ways to restore the missing items.....but your easies method is, to right mouse click on one missing item in the assembly pathfinder, then go to "More" > "Replace Part" [this also encompasses assemblies, not just parts]
Solid Edge ST10 [MP7] Classic [x2 seats]
