Pierce point?
Not applicable
Again, in the tutorial for rectangles, the tutorial states that under relationships,
"pierce point" should be checked. It is gray-scaled and I am not able to check
it. Any ideas?
Chris
Re: Pierce point?
Not applicable
Chris,
A similar tutorial is used for 3D modeling. The same dialog is used for both
2D and 3D. The 'pierce point' option is disabled in 2D. It is not used. So
this is simply a mistake in the tutorial with this dialog being a copy of
the image used in the 3D tutorial.
Ignore the option.
Rick B.
