Placeing a surface flush on a body?
Builder
Builder
Hello all,
I have this surface I would like to align with the face of a body so I may project the hole and slot on to the body and cut it out. I am playing around with this just to learn more abour surfacing I am not interested in simple making a hole and slot using other methods. I am just curious how this can be done. I am a noob still and need some advice.
D.L.B.
Re: Placeing a surface flush on a body?
You have some ways to do this, it depend on what modeling tech is used by you.
In Synch you can use 3D relationships between feces, while in trad (order) you can use Move faces command from Direct Editing group. Or you can do this in assy, atc... Smiley Wink
Here is a video:
BR,
Imics
