Placing the 2d Model on Sheet 1
I am a novice CAD and new Free 2d ST8 user and have a simple question:  How do I place a 2d model drawing on the working Sheet 1 in order to be able to print it with the title block included?
Also, are there any reasonably complete ST8 manuals and/or tutorials that are cheap or free?  I am wanting to use Solid Edge for personal use only and don't want to tie up much money.
10 REPLIES 10
Re: Placing the 2d Model on Sheet 1
From the working sheet where you see the title block: Sketching - 2D Model (in Drawing Views)
This will take you to the background sheet where you can box select the geometry you wish to display.
HTH,
Bob Henry
Manager of Engineering - Highwall Miners
Caterpillar Global Mining LLC
Houston, PA
I really appreciate your quick response, but I cannot find "Drawing Views" on the ribbon and cannot find anyway to place it on the ribbon. I am running the new ST8 version. Your help is greatly appreciated.
Looking in the "Sketching" tab of the ribbon.
Bruce Shand
OK, I finally found the “Drawing Views” under “Tables”. When I select “Drawing Views – 2D Model” it shows the 2D Model with cross hairs to select the area of interest. I select the entire drawing and it then shows the drawing over a very small title block. When I try to shrink the drawing to fit the title block all I do is erase the drawing. I know I am missing a vital point, but so far no joy. Again, your help has been invaluable so far and I think I must be getting close.
Jim
Sent from Mail for Windows 10
The video below shows changing the scale of the 2d view to fit the templates border.
(view in My Videos)
Production: SE 2019 MP8, Testing: SE 2020
http://Grundey.blogspot.com
See attached video:
(view in My Videos)
Bob Henry
REH Technical Consulting
Canonsburg, PA 15317
It appears the free 2d ST8 that I am using is not the same as what all you folks are using.  The main menu on the videos show:
Home  Sketching  Diagram  Inspect  Tools  View
while my ribbon menu shows:
Home  Tables  Inspect  Tools View
I wonder if you are using the pay for use 3d ST8?  If any can help with the 2d model I really need to get past this block.
Jim
Yes, I am using the full SE product, not the free 2D version.
I can't help on the free 2D product. Anyone else?
Bob Henry
I think you can better ask your question in:
http://community.plm.automation.siemens.com/t5/Solid-Edge-2D-Drafting-Forum/bd-p/SolidEdge-2D-Drafti...
There all users use free 2D.
Solid Edge 2019 & AutoCAD 2020 user
