Plane in assy
I am trying to put a plane by 3 points in a assy, create part in place part,
but when i try and select a pick point on the shaded assy, it wont select any points
to start the plane, can anyone help,
Paul
Re: Plane in assy
Hi Paul
Have you checked if the parts you're trying to pick points on are active? It's the only reason I can think off without any context.
Laurenj.
Re: Plane in assy
All seems to be activated, the funny thing is when i am in sketch mode i can do a parallel plane
and select any point on the shaded assy i am working on, but as soon as i change to 3 point plane no points on the shaded assy will work,
Re: Plane in assy
Have you selected the "ALL" filter option?....
Testing: Solid Edge 2019
Re: Plane in assy
Hi Sean,
Yes i have, first thing i done,
Re: Plane in assy
Hi there,
Could you possibly upload a screen recording video of this happening?....higher chance of there being an "AHA, just do this,...like that" moment.
Re: Plane in assy
Hi Sean,
I will have to do it in the morning, getting a bit late here in the uk,
Paul
Re: Plane in assy
Unable to play video. Please try again later.
(view in My Videos)
Worked it out quicker than i thought.
Paul
Re: Plane in assy
well not sure what has happened here, but still having
a problem selecting the shaded assy to create the new part in place on the sketch command and create plane from 3 points.
will try another video later.
Re: Plane in assy
If all else fails, try changing your application display settings under Solid Edge Options | View.
I've seen unusual highlight/select behavior in assemblies that goes away when simply changing the display settings to something other than what is enabled.
-Dylan Gondyke
