Please help
When I try to extrude a Rectangle from a sketch by clicking on the direction arrow the sketch glows green and  the system locks up. Have to press ESC button to get back to sketch.
In order to get your question to the right forum, what pr...
Siemens Legend Siemens Legend
Siemens Legend
In order to get your question to the right forum, what product are you using?
Jerry
Jerry Sarfati
Siemens PLM Software
Re: In order to get your question to the right forum, what pr...
Product is Solid Edge ST6
David Treanor - Director
Email: david.treanor@magefekt.com
Mobile: 0404 008 823
Web: www.magefekt.com
The content of this email is the property of Magefekt Pty Ltd. The information contained in this communication may be private, privileged, and protected from disclosure. If you are not the intended recipient, any distribution, copying or other use without written consent is strictly prohibited. If you have received this electric message in error, please contact sender immediately and destroy the original message and all copies.
Suspect it is a system setting/incompatibility [usually g...
Hi David,
I suspect it's a system setting/incompatibility [usually graphics] related issue.....could you give some info on your PC spec's?
Also, what version of Solid Edge ST6 is it?  [Commercial or Student Edition]
You migh try going to [in a new "Part" file] the Solid Edge Options, and under the View tab, change the Application Display to "Backing Store".....see if this gets it going.
Testing: Solid Edge 2019
