Primary caption links
Hi
Is it possible to link Parts list colums to primarty caption?
If part 2 is item 12, i want Item 12 to automatic apear, and if part 5 is item 1and so on.
Betreff: Primary caption links
Hi @Arild
BOM items always are linked to there caption, isn't it?
Or can You further explain Your request and Your goals?
Yes they are, but i want a spesific colum linked.
Hi @Arild
even if it would be possible to link the "View Property" to a shown part property, I never would do so.
Simply use a callout text with the item number involved
I think this is easier, more flexible and robust.
Re: Primary caption links
You have two choices.
Use sorting in the parts list. Display the item number the parts list is using. This does not work for flat pattern views.
The other option is to manually assign part number for every part. Lot's of work if you have lot's of parts. And lots of work if you change your mind.
Thanks for all responds :-)
Today i assign part number manualy, and i know how much work this is if o change my mind of it...
Ill try to display item numbers from part list, then half my work is done.
