Re: Print Drawings
Hi @Johan,
IIRC, with the large format HP printer at my last workplace, it was just as @rehenryjr points out.....the actual graphical title block frame drawn into your background sheet needs to be smaller, rather than trying to adjust the listed sheet size.
Try increasing the offset distance from the sheet edge limits, by moving your boarder inwards.....I'm sure there is a dialogue for the printer that states what the "effective print area" is, and that is what your background needs to be within.....not just the paper limits.
