Re: Print object with wrong measures
I create the piece Solid Edge and I export to * .stl , however , when I open the part in Repetier , it is much bigger than the one I did in Solid Edge. What is the problem?
MLombard
Retired
It may be a difference in export/import units. Have you meaured the size difference? Does the difference come out to some conversion factor that may be the difference between metric and inch units?
I created the file in ISO Metric.par.
I exported it to * .STL with the options:
Binary.
Conversion tolerance: 0.01
Millimeters
Hi @Pakito,
What about the import settings on the Repetier program?....would seem like it is seing the units differently than those SE is sending.
Will be my Repetier settings that are wrong? The files are to be added in Repetier in millimeters .
Hi @Pakito,
Have you seen this blog post....?
https://community.plm.automation.siemens.com/t5/Solid-Edge-Blog/Easy-3D-printing-from-Solid-Edge/ba-...
