Print scaling option not sticking under Paper Print
Under Paper Print > Settings > Scale, if I select "Fit to printer margins," click OK, save file, exit out of ST9, open the same file back up again, the radio button of Manual Scale is still selected.
I'm confused. The only thing I can think of is that the file was made from a template w/that manual scale setting, but it has been saved as something else, so it can't be getting that setting from the template (can it?). Or perhaps this is a setting on my canon printer itself that needs to be modified.
Any point in the right direction would be appreciated. I tried searching the forums here and on eng-tips.com, but haven't found anything definitive just yet.
Nate
