Print solid works drawing
Honored Contributor
Honored Contributor
I was sent some solid works files expecting to be able to print the drawing.
I can't even open the drawings in solid edge. The models open fine.
The free eDrawing viewer from DSS allows me to look at the drawings but not print.
Do any know of a way to get the Solid works drawings printed without purchasing software?
I ask here because many may  have have run across the same problem.
EDIT------
Never mind. The print tool in the edrawing viewer was cleverly hidden.
