Printing draft with overlappping views
Hi Edgers,
I already search within the forum for older articles since I thought there was a solution a time ago, but haven't found anything as solution so far.
With ST9 MP2 we again see the problem with result at paper doesn't be equal to printing preview or with export to PDF and we think it wasn't so with ST8.
There is a an shaded ISO view of an ASM (or part) which is nearby the BOM.
Preview shows no problems, saving as PDF doesn't produce wrong result (there is the option set for transparent backgrounds) but printing to paper results in view overlapping error.
20161116_1547.pngPrint Preview20161116_1548.jpgPaper Result
I thought I remember that there was a registry entry to solve that behaviour for paper printings too.
Does anybody remember?
PS.: besides changing the view border geometry
Wolfgang
Re: Printing draft with overlappping views
Try this:
"HKEY_CURRENT_USER\Software\Unigraphics Solutions\Solid Edge\Version 10X\DEBUG
Create a new 'DWORD (32 bit) value "STRETCHMASKBLT_VERSION" and set it to 1.
BR,
Imics
Hi Imics,
Yes that was it and it solved the issue!
Thanks.
Wolfgang
@hawcad, great! Smiley Wink
BR,
Imics
