06-18-2013 08:41 AM
With Solid Edge ST3, how can I print a drawing at a 1:1 scale of the object for an 8' x 12' object. I would like to create an actual size stencil of sorts for the object.
Solved! Go to Solution.
06-18-2013 09:09 AM
06-18-2013 09:38 AM
06-18-2013 09:50 AM
06-18-2013 04:16 PM - edited 06-18-2013 07:47 PM
I do this from time to time in Solid Edge...it's not too difficult. In cases like these, I use "draw in view" and make an appropiraite sized grid of reference lines, in order to match up the prints later, then use "print area" capturing enough to fit inside of the paper size, adjusting the target area to remain at 1:1....& repeat.
Solid Edge ST10 [MP6] Classic [x2 seats]
