Problem : Name change after export ( -oa(number) )
I work under ST5 academy.
I created an assembly with multiple parts and assemblies.
I need to export my project to another software, for that I pass in .STP.
After export, the names of my assemblies and parts change.
They end up with a suffix -oa (number).
What should I do to avoid having to change names.
Thank you in advance.
Cordially
Before export
After export
Re: Problem : Name change after export ( -oa(number) )
i'm assuming your opening back in SE? I tried the same and couldn't duplicated
I opened it with SE but it gives the same with SAP Visual Enterprise Author.
I need to find a solution because I have 100 models. I can not rename all the pieces one by one.
If you open it to the same location as the original you will get different part names to prevent original data being ove-written.
You should always open to a different folder.
HP Z420 16GB RAM
Quadro K4000
ST10 MP3 on Windows 10 Pro 64.
Esteemed Contributor
"You should always open to a different folder"
I'd be curious to see if this solves the problem. I've seen this behaviour when I've opened SE originated step files from remote sources with no corresponding part names anywhere on my side.
Bruce Shand
I already opened in a different folder.
I have everything well set "available".
I've done updates.
The problem remains.
@Thaom
"The problem remains."
I'm not surprised. Even with this unresolved it wouldn't be so bad if revision manager could use wildcards in its find/replace capability. But, alas, it can't.
Bruce Shand
So there is no way to avoid name changes ?
Have you asked your VAR or GTAC?
Bruce Shand
VAR ? GTAC ?
