Problem about import IFC file
Hello all,
I opened an IFC file with solidedge ST10 .asm, but some parts are upside down.
I checked the IFC file with BIM vision and the original model is correct.
I tried to find converting setting in solidedge, but couldn't find anything related to the reference plane.
Thanks for checking my question.
best regards
3 REPLIES 3
Re: Problem about import IFC file
@Hunter_Han
I have seen this on some imported model.
Pls report this to your support channel and they will log a Problem Report for you.
Good luck!
/ulf
Siemens EMEA GTAC Support
Thanks for the reply.
I tried to get web support, and it need me to log in with my webkey.
But I can't log in with the same account I used here. I never used this to report problems...
best regards
@Hunter_Han You would be better off contacting the reseller partner you purchased (or were assigned if you puchased on the web) Solid Edge from.  They can create a Incident Report for you and will know what info is needed to explain the issue.
Production: SE 2019 MP8, Testing: SE 2020
http://Grundey.blogspot.com
