Problem in isometric view
Hello all solid edge masters..
I'd like to ask you about the problem that I am faced now.
When you see this picture below, you can see that there are a few lines that can not show when I import from 3d view using "view wizard" feature. Can all of you help me to find a solution?
Problem.jpgWhen you see this picture, there some strange
Re: Problem in isometric view
Is that Round / tangent geometry that missing form the view.
try to swith on show tangent edge style from the drawing view properties
No, I mean for the edges. Not all, but there are few edge can not shown
have you tried switch on the tangent edge view as i mentioned before and see the different?
Hello  @nico_vici1611
Apart from the solution by @Destian, also in the Drawing View properties dialog, take the Advanced tab and select "Process Intersections" - "Create all face intersections
Update the drawing view by right-clicking on it.
~Tushar
