Problem installing ST3 on Vista
I was using ST2 on Windows Vista, and downloaded ST3 successfully, then got caught by the UAC message which I turned off. After this install would report that it was 'interupted' and to retry. Retrying failed again. I was able to install by creating a second user ID and installing using the second ID.
