Problem on corners sheet metal
Dear Sir Madam,
I am a new user here, but we had solid edge V14 before, now in our company we  bought the latest version of Solid edge.
I have problem  on corners (sheet metal No1_2.psm) in practise it is okay but in solid edge for me is not okay.
if someone know how to fix it, I will appreciate it!!
please see the attached file (unzip it)
Sincerely
Theofanis
Re: Problem on corners sheet metal
Here is a video what can help you:
I suggest to use Part to Sheetmetal command (new in ST7) in this case!
BR,
Imics
Dear Imics,
Sorry it's taken me so long to write!
thank you very much for your work, I appreciate it !!!
it is possible to close the corner with an easy way, such us Bend corner?
Sincerely
Theofanis
