Problem to import .DGN file (microstation)
Hy everyone
I'm trying  to open a .dgn (microstation) with ST8 but can not complete the operation, I tried with various template (.par .dft .asm) but no one works.
Anyone have any suggestions-indication ???
Is able ST9 to open .dgn file (microstation) ???
Alex
Betreff: Problem to import .DGN file (microstation)
Honored Contributor
Honored Contributor
in former version there was a Microstation interface available for reading there files.
But this was dropped a couple of versions ago besides the fact that only an older Microstation version was supported.
So IMHO there no longer is an option to read in such files directly.
Wolfgang
Hi Wolfgang,
I keep in view what you have told me
Thanks for your help
Re: Problem to import .DGN file (microstation)
From GTAC Solution Center article 002-7008407...
Microstation to Solid Edge Data Translator
Symptom
Since ST9 I cannot open files from Microstation (.dgn)
Hardware/Software Configuration
Solid Edge ST9
Solution
Microstation .dgn is no longer a widely accepted format for mechanical drawings. In 2003 with Solid Edge Version 14, the Microstation translation capability moved to an “Extended Support" status where we no longer provided fixes or enhancements.
Solid Edge ST8 was the last release where the Microstation translator was delivered.
Additionally, from another GTAC Solution Center article 002-7002946...
What version of Microstation file can be imported into Solid Edge?
Symptom
Solid Edge ST 3
Solution
Version 7 of Microstation is the last version of Microstation that can be opened into Solid Edge.
Thanks so much uk_Dave,
I was not practical with the solution center, now you have opened up a new world for me.
Alex
Not sure what the latest version of Microstation is or will do, but Microstation V8 will save as Microstation V7.
Can you get the people who supplied the file to do that for you ?
HP Z420 16GB RAM
Quadro K4000
ST10 MP3 on Windows 10 Pro 64.
