Problem to "open with" dwg file
Hello everyone,
I installed the ST9 version(unistall the ST8), but when I try to open a DWG file with "open with" seems to be is connected to st8 old version and dont start the file in software;
Everyone know which registry key handles this selection, and how is it compile???
Thanks to everyone
Alex
Re: Problem to "open with" dwg file
Try my registry hack from my GitHub site:
https://github.com/uk-dave/SolidEdge/blob/master/open_dwg_in_solid_edge.reg
This should clear your existing .dwg file association and reset it to open with Solid Edge as the default
