Re: Problem to run Solid Edge ST9 Student Edition
Hi Hawcad.
I re-installed the solid edge in an external disk and when start the program again show the error Smiley Sad and the same patch in Windows.
I don´t know what to do.
Thanks for your help.
Diego
and when installing, You first have turned off the UAC, started the install as administrator?
Wolfgang
Hi.
How I can install again Solid ST 8 Student version?
Diego
