Problem to run solid edge after windows system formatting.
N/A
Hello there
I had used student version of SE, then due to system malfunction i had to format it but i left installation file so It wouldnt be need to download it again(I have low speed broadband)
But when having system reinstalled and then se st5 either, dialog box says that my copy should be licensed for first time use.
How to obtain my old licence?(I entered my data at siemens server previously) How to work still on that credentials?
Re: Problem to run solid edge after windows system formatting.
Esteemed Contributor
Hey there,
Darn, that's inconvenient....but precisely why I recommend having a back up of both, download and license files. Thankfully its not a big drama to get it back again.
If you re-apply your sign up at the Siemens page, a new license (assuming you don't have the original any more) file should be sent with the email, as before.
Streetscape Limited (NZ)
Sent from my Samsung Galaxy NoteII using Tapatalk 2.
Solid Edge ST10 [MP6] Classic [x2 seats]
N/A
Thanks I will try it.
