Problem with Auto Connect in Simulation
I have created a rather complex frame with metal sheets on it in assembly adn i want to mesh and solve it.
All parts are supposed to be welded.
What is the best solution for connecting it in simulation mode?
So far the only solution that worked was autoconnect using glue but in this case my construction will collaspse.
Any suggestions? Smiley Happy
Re: Problem with Auto Connect in Simulation
Esteemed Contributor
Why would the glue connector cause it to collapse? That it's the connector you should probably use...
Production: ST10 MP3
Testing: SE 2019
