Problem with Life Cycle Assistant
I was just releasing a number of files in design manager (insight manage files) and got this error on one of them:
After the error the LCA closed and when i open the command again I get this:
And I can't click cancel. I have deleted translog.xml but the problem remains. What to do?
Re: Problem with Life Cycle Assistant
After deleting the file  "RFMSLca.tmp" in AppData\Roaming\Unigraphics Solutions\Solid Edge\Insight\Cookies(user)
LCA is working again.
Did all the files you wanted released show up in the released folder(s)?
No, none of them did, I hade to run the LCA and release them again. As for the file in the error message I still dont know what caused it but I was able to release that file logged in as admin.
