Problem with SE st8
If i run Solid Egde and select a new part ( create part), program is crashes. How can  i solve this problem? In attachments is crashlogf.
Re: Problem with SE st8
That might indicate graphics card.  The driver in your log file is listed as version 10.18.14.4062.  The latest one on the Intel driver site for your listed GPU is 15.40.10.4300.  I would upgrade to this driver and then try again.
Production: SE 2019 MP4, Testing: SE 2020
http://Grundey.blogspot.com
Siemens Legend Siemens Legend
Siemens Legend
Hi @MichalR
@KennyG is correct.  The crashlog does show that the crash occurs in the graphics driver, in the atig6pxx.dll file.  Try updating your driver to the latest version.  Let us know if that doesn't resolve your issue.
Melanie
I solved this problem yesterday because I have two graphics cards in my laptop so i just turn off the second graphics card and Solid Edge is working correctly now.
Thanks for your repleys.
