Problem with Student License
N/A
Hello. I installed Solidedge thanks to the site siemens.
They gave me a license called SELicense_4429.tkt
I don't know if I have to let the ".tkt" or if I have to change for ".dat" because when I open the Utilitary License, I have to choose between 3 type of License ( License.dat + name of servor , with webkey username and password, or 12 characters key for SolidEdge National Academy ).
I only have my SELicense_4429.tkt so I don't have 12 characters key and I don't have webkey acces. Then I don't know the name of one servor.
I hope I'm clear and I would like to know what to do to install my license.
Re: Problem with Student License
N/A
Try to rename SELicense_4429.tkt to SELicense.dat and copy it to:
c:\program files (x86?)\solid edge ST4\program\SELicense.dat
After this, try to launch SE directly, without run the SE license wizard.
This worked for older relaeses of solid edge, I hope it still works for
newer releases.
N/A
Alessandro you are the best !
