Problem with activation of Academic Code
Hi!
I have installed new version ST7 but I've got a problem to activate it. After selecting "I have an Academic Code"; a "License Key" field filled with A-Code, the "OK" button  is not active? What should I do?
Thanks in advance if someone can advise me.
Wbr,
Uve
Re: Problem with activation of Academic Code
How do I get the activation. I just installed ST7 and tried to use it. a page said I need an activation code. No code came up when I opened the Academic box. Thanx for your help.
