Problem with bend radius in master part. Help.
Builder
Builder
I have this master and when i try to create a child part the child part radii stays at .118? I need to correct this. Everything else works flawlessly. Thanks. Your input is much appreciated.
Re: Problem with bend radius in master part. Help.
You problem comes, that you have overwritten default bend settings! If you restore it then it will works well!
Here is video:
BR,
Imics
