Problem with graphic.
N/A
I'm using Solid Edge SP6 on my laptop, and the graphic in the program is too advanced for my machine. Is there any way to reduce the level of graphics for less advanced? Thanks for help.
Re: Problem with graphic.
Esteemed Contributor
Hi there,
If you open a new "Part or Sheet Metal" session, then go to Application button > Solid Edge Options > View tab, there is a panel for "Application Display", change it to "Backing Store" to get the most reduced setting available.
Solid Edge ST10 [MP6] Classic [x2 seats]
