Problem with openig file. Error message : "UNABLE TO CONNECT TO THE REMOTE SERVER"
Hello
When I want to open any file type ( part, assembly, drawing ) after long time (about 20 sec) I always get a massage:
"UNABLE TO CONNECT TO THE REMOTE SERVER". Also when I"am closing files I get the same message:
"UNABLE TO CONNECT TO THE REMOTE SERVER". Anybody know what to do?
Marcin
3 REPLIES 3
Betreff: Problem with openig file. Error message : "UNABLE TO CONNECT TO THE REMOTE SERVER&quot
Hi @SUCHY
is the connection available for normal file access?
Wolfgang
Hello
I few moments ago I solved problem.
I excluded edge.exe file from Windows defender firewall. Now everything works ok. No error message.
I dont know why it's happened. I didn not made any changes in my windows defender.
Byt now after excludind edge.exe from defender everything is ok
Hi @SUCHY
so as my assumption was:  "Anti Virus Software"
But fine that now everything works fine again.
Wolfgang
