Problem with sheet metal contour flange along edges
Builder
Builder
I have a sheet metal part with a cut-out section that I am trying to run a contour flange acround, the flange will not run the full length of the edges of the cut-out (error message) please take a look at attached screen shot and let me know how to do this, thank you
Betreff: Problem with sheet metal contour flange along edges
Hallo,
maybe the problem occurs earlier in the process?
The corner man can see already will not be able to be flattend at all.
I tried a similar situation using a hem feature and SE will make it al edges arround.
Wolfgang
Honored Contributor
Honored Contributor
I end up using ordered sketches of flats that include the flat for the hem and have lines in the sketch for use of the bend command down stream. When adding the bend, 0 deg (180 deg), and 0 radius (very very small).
Pain in the $%^
Builder
Builder
Hello Wolfgang
With the hem feature you refer to, how do I set the hem raduis in the opposite direction ?
Honored Contributor
Honored Contributor
I find that I can't change cirections on flanges, delete and re-do.
Builder
Builder
I completed this using the dimple feature which works very well indeed, screen shot attached Smiley Happy
direction is based on the selected edge, AFAIK
Wolfgang
