Problems opening a .stl file
hello,
I am trying to open a .stl file, it is giving me an error ' invalid certification'. how do i solve this error?
kindly help
Thanks.
Ashish Sarode
Re: Problems opening a .stl file
Hi @iashishsarode1:
Are you opening the STL by double-clicking in Windows Explorer?
Does this message appear when using the Solid Edge Open command ?
If so and possible, attach the STL to reproduce the problem.
~Tushar
Community Manager
On a lot of systems by default STL registers as some sort of certificate. I am not sure what this is exactly. Instead of opening from Windows Explorer - where it is trying to run some certificate reader -- Open Solid Edge, then go to File Open in Solid Edge and browse to the file. Should open fine.
DS
Dan Staples
