Problems opening asm file
Hello Edgers!
When I try to open an asm file of the ST5 version with ST10 I get this error.
Any idea?
Xènia Turon.
Re: Problems opening asm file
Sounds like a corrupted file.  If under active Solid Edge maintenance please submit to your support contact for file repair.
