Problems to add parts to an assembly
Hello everyone!
I have a problem with a big assembly.
I've been working with it few days ago and, when i add an alternate assembly something occurs, now it is impossible to add anything tho the main assembly.
I can open the subassemblies and add parts normally.
I been working on the server all time but I have all the permissions and I made all the parts and assemblyes.
I can't change the alternate assembly neither.
Any idea?
Thank you!
Betreff: Problems to add parts to an assembly
Hi @BeatrizSeoane
for Assembly Family there is - as I can remember - a button like "apply to all members" or so.
Maybe this one must be set to on
Wolfgang
Hi!
Thank you @hawcad but I check it!
The issue is more complicated that I expect so I send everything to the GTAC.
Thank you
Hi @BeatrizSeoane
this will be the best for that case
Wolfgang
