Problems to center Slot
I'm fairly new to Solid Edge but enjoying it a lot so far Smiley Happy
I have a problem with centering a Slot in Sheet Metal, it does not move when I change the width of the Flange - it just stick to the same place.
Is it not possible to attach relations, like you can do in Solidworks?
I uploaded a small video of my problem:
https://www.youtube.com/watch?v=rLo7AqgNZl4
Kenneth
Re: Problems to center Slot
LMGi
www.TLMGi.com
Hi Kenneth,
You can do this either:
1. By adding another dimension (distance between) the edge of the flange and the center line of the slot and adding a relation in the variable table. Or
2. By adding a Horizontal/Vertical face relation in Sync between the slot center and the midpoint of the flange:
~Tushar Suradkar
you need to create a 3d relationship there with face relate.
see video here:   http://screencast.com/t/zZsnzvsy
That worked, thanks a lot Smiley Happy
