Re: Property text code: where to find them?
Hi @bshand
OK, good attempt, but You are using the Feature Callout here (%HC) which itself is a summary of several other feature references.
So You have to switch over to the real HC settings and from there You can format it as You like
Wolfgang
OK. Or here:
Thanks, my friend. I've never used this feature before. You may have been able to tell.
Bruce Shand
Hi @bshand
only click into one callout text field, this again should show You the formate button for it.
Wolfgang
I get it.
Bruce Shand
