Propriety dft modified by excel
edit: Sorry, I wanted to write about solidedge development forum
Hi all,
I opened this topic: https://community.plm.automation.siemens.com/t5/Solid-Edge-Forum/Link-excel-to-property-draft/td-p/4...
I need a link between excel and the property draft. see the image attached
Thanks you  so much
PS: Sorry for my english Smiley Happy
Re: Propriety dft modified by excel
From Excel to Solid Edge, no problem.
From Solid Edge to Excel. Don't bother trying. If that's the directions you want, there is no way to make that update. you can do one time copy and paste.
Thanks 12GAGE,
I want from  Excel to Solidedge, I have a file excel with all propriety and I want export to Solidedge.
I want the same that the macro VBA bearing but modify the propriety dft
THanks
