Protrusion With or Without Sweep
With this new drawing requires a protrusion a sweep and a sweep without protrusion.
Send with a short video
https://www.screencast.com/t/TSlGbawR9L
Greg
Betreff: Protrusion With or Without Sweep
Esteemed Contributor
Hi @PO_LC
so sorry to say, but I can't get YOu what Your question/request might be.
You want to create a sweep/protrusion or what?
But You already have some extrusion there.
Loop is a selection tool of Solid Edge what allows You to first select a face and afterwards You can select from any closed loop in this surface which doesn't need to be chained, what further is a tangent continous loop tp be prcise.
Maybe You can better describe what You want to do and I am 100% confident that then You will get the proper answer tooo.
Wolfgang
I want to create a sweep using a protrusion and a sweep without protrusion.
With this drawing, I want to create a wire with a curve.
I do not know how to do this.
With the drawing of reversible auger using the sweep didn't work, however, finding the heli command did.
Greg
