Question: Add a material to mattable?
Hi all!
      When I program to add material to library,the following question encontered:
      My programe is as follows:
      string[] aa = new string[2];
      aa[0] = "abc";
      aa[1] = "def";
      objmat.AddMaterialToLibrary("mat_A", strLibrary, strMatPath, aa.Length , aa, cus_FaceStyle, cus_FillStyle);
      object a1 = aa[0] as object;
      objmat.SetMaterialPropValueToLibrary("mat_A", strLibrary, SolidEdgeFramework.MatTablePropIndex.seDensity, a1);
     Program excuted succeed. But "mat_A" has not properties except “Density”。Object  “aa”  assignment is not successful。  Robot Sad
     When I replace "mat_A" with a input value, for example: textBox1.Text.Trim(), The "SetMaterialPropValueToLibrary" has a exception: "Unspecified error (Exception from HRESULT: 0x80004005(E_FAIL)) "   Robot Mad
     Does anybody know what  is  wrong ?  THKs.
     solid edge ST7 MP10
     C#  2013
Re: Question: Add a material to mattable?
you could post your question in the Solid-Edge-Developer-Community
Yasser
