Question On Revolve
I've been attempting to create a 45° curve with this out of ordinary document. This document is to show, I am able to the first half of the curve. I cannot create the second part of the document.
http://screencast.com/t/AuqCu2ySPPQn
Thank You
Greg
3 REPLIES 3
PO_LC Not sure what you're trying to do but maybe this wi...
PO_LC Not sure what you're trying to do but maybe this will help watch video: http://screencast.com/t/GlZQgTd9h Bob
You need to change your Connected Faces option to Lift.
http://Grundey.blogspot.com
Hi,   Adjust Live Rules face selection   Thanks
