Question coppy sketch from Autocad to design in Solid Edge
Dear all
I have designed this products but have difficulty in step coppy sketch from autocad file to Solid Edge and design as shown picture. Please show me the steps performed by video.
Autocad file and Solid Edge file in attach
Best Regard,
BuiTu
Re: Question coppy sketch from Autocad to design in Solid Edge
Hi there,
You need to open the ".DWG" file in Solid Edge [being a 2D only handler, SE will default to Draft], then when it is open, then copy the required elements from the draft file, and paste into a sketch for you part file.
Testing: Solid Edge 2019
