Quick Sketch Question
Builder
Builder
I am having difficulty sketching the S shape in this clamp so that it is continuous and tangent and can then be used to create a contour flange in sheet metal. I want to draw from the inside diameter then "extrude" out in sheet metal. Can anyone show me how to do this? Thanks!
Solid Edge Noob
Re: Quick Sketch Question
Builder
Builder
attachment didnt upload
Is the attached model, what you are looking for?
I am not sure about the dimensions at this S-shape.
Builder
Builder
Yes that is it. Could you post a video of your method? I ended up with the same result but I am always interested in better methods.
Attached is the movie that shows, how I have done this.
