Quick View Cube
Builder
Builder
My Quick View Cube has dissapeared, although my setting is checked to show it. Any ideas?
Re: Quick View Cube
Solid Edge App button - > Solid Edge Options (3D environment) -> View Tab and here you have to use Graphics Cars Driven (Advanced) at Application Display.
I hope this helps!
BR,
Imics
Re: Quick View Cube
Builder
Builder
Imics-That did work, thank you!
Re: Quick View Cube
You're welcome! Smiley Wink
BR,
Imics
Re: Quick View Cube
I reset the view options as advised and the cube appered but now two days later after a re-boot it has gone again and re-enetring the settings has not corrected the issue.
I have a home licence running on a an HP Touchsmart and the cube is visible at all times no matter what the settings.
Is there some other issue I am missing ?
Re: Quick View Cube
I had same problem with cube.
I was able to solve its disappearing by going to system registry and delete this particular key:
HKEY_CURRENT_USER\Software\Unigraphics Solutions\Solid Edge\Version 107\PrefSets\Options-View
This did the trick for me. Hpe this helps.
Ota
Re: Quick View Cube
me too
and I tried to solve it but it cann't
Re: Quick View Cube
Thanks Ota but no success with my installation. I deleted the registry key as suggested but nothing changed. I still cant get the cube up ?? I am wondering if its related to the graphics card (NVIDIA).
Anybody else have any bright ideas??
Re: Quick View Cube
Paul,
you are welcome.
It is strange, that it did not helped. I also have nVidia card (K3000M). Mabye you can also try  switch between different graphics settings in SE Option. It might help. If not, you can fill an IR to development.
Ota
